Jubilee hyd. pump
leroy9804
How do you check the Hyd. Pump on a jubilee ford to make sure it is working? The tractor has a bush hog attached it. Will only lift it about 3".
This post was edited by leroy9804 on 11/07/2021 at 09:19 am.
Make sure your selector lever is in position control (vertical).
Is the reservoir full?
How does it lift with no load?
(quoted from post at 19:52:05 11/07/21) Make sure your selector lever is in position control (vertical).
The selector lever is vertical and the reservoir is full. I did not try the 3 point with no load. I am looking to but it but afraid it might have to replace the pump. I would have to drive about 30 miles to check the no load test.
Melvin
I'm just going by what the FO-19 shop manual is saying. My NAA is lifting fine so, I've never had to get into it.
It basically is saying, that it could be a relief valve or the pump. It says to remove the inspection cover on the PTO shifter side and with the engine running at a fast idle and the control lever to the top of the quadrant look to see if oil around the area of the relief valve is turbulent. If so it is the relief valve leaking, if not it may be the pump. If your tractor has the vane type pump, you could try turning that nut at the front if the pump clockwise to increase pressure.
Also, you might want to post this on the Ford forum above this one and see what other advice you get.
