jubilee hydraulics
dlp
Sometime back, I rebuilt the square hydraulic pump on my father-in-laws Jubilee. I used it the other day & noticed a problem. When lifted to the top with a bushhog on it, it would drop a little bit & then come back up, drop again, & repeat this consistently. What is up with it? Thanks in advance!
This is fairly common for the NAA tractors. This is caused by wear on the control valve inside the lift cover and leakage because of this. It is much easier to live with this than try to find the correct size valve to replace it.
Dan
