Over the last 10 years I've owned a 9N and (4) 8Ns. I recently bought a well-used Jubilee.
A compression check showed fairly good compression in cylinders 1, 2, and 3. Cylinder 4 showed about 30 psi. I checked the gap between the valves and rocker arms with the piston at TDC and found no gap.
After adjusting the gap to .015 I got 100 psi in the cylinder. I just wanted to pass this along to those who may be having a similar compression problem. YMMV.
