johnnymac
I am hooking up a loader to my Jubilee tractor. I need to know where the drain for the hydraulics goes Where is the dump for the hydralics
What kind of loader is it? Does it have its own front mounted pump, or are you using the 3 point hydraulics pump (it will be really slow if you use the 3 point pump).
If it has its own front mount pump then the sump is usually inside the loader frame.
If you plan on using the tractor's 3 point pump then the sump is in the rear axle center housing, behind the transmission and in front of the differential. How you are going to plumb the loader valve into the 3 point circuit will tell us the best way to connect the return back to the sump. If you have a dual acting remote valve under the seat that you are powering the loader with then you can simply use the other side of the remote valve for the return. If you are using a diverter valve or are using the test port on the top plate then the easiest thing to do is replace the fill plug for the hydraulic sump with a fitting to connect the return line to.
how about posting back and using a few more words. Descriptive words and sentences.. that way we aren't having to guess exactly what you are talking about.
