lrsouth
53 jubilee with lift problems. will not pick up unless tractor is @ idle. was working great. if you leave lift up with a small load on it,(scoop) it will stay up for over 30 min after tractor is switched off.
Sounds like your hyd fluid is real thick and or has water in it and might be partly froze. I would check your fluid and if milky looking change it. If that does not work you may have a leak in the suction line or your pump maybe getting weak
