Olliejunkie
Anyone use one of these? Think they would start a old gas tractor without a battery. I like to start mine every now and then but hate playing musical batteries.
Thank you for all the replies. I may try one. Would be handy to have in the car anyway. A guy at work had a small one. He was always leaving his light on.(quoted from post at 06:00:58 05/03/19) Crazy Horse, it would depend on what type electronics it has.
If it has an alternator or electronic ignition conversion, then it could damage something IF the jump box were disconnected with it running.
If it has a generator and points or magneto, it would not hurt it.
But either way, as long as the jump box was left connected it would not know the difference in a jump box or a battery.
Now if it were a 6 volt with battery ignition, it would eventually overheat the coil and arc the points, but it could still be run intermittently just to keep the rust out of the cylinders.
(quoted from post at 11:59:22 05/03/19)Thank you for all the replies. I may try one. Would be handy to have in the car anyway. A guy at work had a small one. He was always leaving his light on.(quoted from post at 06:00:58 05/03/19) Crazy Horse, it would depend on what type electronics it has.
I couldn't believe that little thing would jump it. I guess I still dont eventhough I saw it work. Also heard other good things on other forums. Thanks again.
Thanks Hobo. Some of my tractors only get started once or twice a year then get driven around the yard. I get tired of packing batteries around and lifting them up over the hood. Was thinking of buying a new battery or two but I can buy one of these for near the same price. Just a thought I had last night and picked one off the internet real quick for an example. Time for some more research. I was pretty impressed with the video you shared.(quoted from post at 10:09:14 05/03/19)
Like you I have a couple tractors I use 30 min. a year at the most I use that jump box I posted on the dead dead dead battery's until last year they both have electronic ignition.
I made a battery box on one that mounts to the side of the tractor so I could put any battery in it then put maintainers on them...
Those little jump boxes do work and work great even without a battery :shock: I am not promoting use it without a battery tho I have... Most of the time with no battery its on a small engine with electric start that has no battery..
Those JNC are good also but they don't have the punch that micro start does are longevity either...
