jump starting a 8n
rustd
i have a 49 8n with a 6volt system how do i jump start it with 12 volts? what do i hook the 12volt postitive to?and the negitive?
If you are following tip # 43, it doesn't matter. All you're doing is putting current in the starter. Put the positive cable from the 12v battery to the stud on the starter.....or the negative cable. Doesn't matter.
50 Tips
(quoted from post at 22:51:21 09/11/09) If you are following tip # 43, it doesn't matter. All you're doing is putting current in the starter. Put the positive cable from the 12v battery to the stud on the starter.....or the negative cable. Doesn't matter.
50 Tips
Did I say something about the 10,000?
I need to know if the starter can be installed if the bendix is engaged and if not is there any way to get the bendix back BTW I have the old style bendix with the big spring??? Thanks
