jumpy clutch
Ranchinelec
Just put new Cab mounts on our 970. Also replace the modulator spring on the back of the clutch spool. Thought it would drive like a new tractor but it still jumps. If you let the clutch out a bit the cab jumps up a bit letting the clutch out more. This starts the jumping action. Do not have the Hood on the tractor and the fibreglass front is trashed. Is the structural integity compromised if the hood and all the side panels were not bolted on. I was thinking that if the panels were bolted down, that would keep the cab from jumping up when you let out the cluth. Your thoughts...
Ranch.
did you replace all four iso mounts? if so I have a 970 that was like that and under closer inspection the platform ( the item the iso mounts bolt to) was broken in three places, also from all of the movement had worn most of the cab to platform bolts almost in two replaced all of the bolts welded up platform and problem solved cnt
