just woundering
I don't know that Fuel injector cleaner would do any harm. I do know that I use a product in my '49 8N called "Yamaha Ring Free" additive. It keeps the pistons clean of any carbon or build up. I've used this since 1986 without any trouble. My oil pressure is near 50 lbs when startup and 35 lbs with a hot engine.
most fuel injector cleaners will clean carbs too.. so.. no.. it won't hurt.. many cleaners have a lil dry-gas ( alcohol ) in them.. though with ethanol based fuel.. water usually don't stay long anyway these days..
soundguy
The Lucas product for Fuel System Cleaning is a really good product too. I use it in all of my stuff, gas, diesel and 2 stroke. No ill effects and much better performance after a few treatments. You mix it something 3oz to 10 gals of gas.
I use Yamaha Ring Free too. Mostly use it in two cycle enginge, but do run it thru a diesel tractor every now & then. It isn't cheap, but it seems to work. And I don't think the injecter cleaner would hurt anything.
Carb cleaner or injector cleaner there probably isn't a difference in them other then what the label says. So yes it will not hurt a thing you can also run MMO or ATF in them and not hurt them
