Been having trouble with kohler 12 hp motor. Was venting pressure thru carb. Ground valves and found burnt piston. Still had the problem. After all was said and done I found the muffler plugged up. Was mowing last night after about an hour and a half it siezed up. I had the oil hole on the rod end toward camshaft. and all clearances checked ok. Any ideas what might have caused failure?
