Kabota B71000 question
old
Any body know how many quarts of oil it takes to change the oil in one?? I have a guy that wants me to fix a problem on his which I have the parts on order for and at the same time he wants me to change his oil. Problem is I don't know how much oil the engine holds. I figure on using Rotella maybe 15W-30 etc but need to know how much to get.
Hobby farm
Old most of the big engines hold 3 gallons but If I was you I would drain it and then look to see how much comes out. Make sure you get the correct oil weight and type for this engine.
Walt
This is from the Kubota website.
for a B7100HST DT(Dual Traction)
The kubota website has a parts quick reference guide for each model. You have to enter the model you have.
Fuel 3.4 Gal.
Cooling 4.9 Qts.
Crankcase 3.6 Qts.
Transmission 14.4 Qts.
Hydraulic The oil used to lubricate the transmission is also used as hydraulic fluid.
Axle Front diff. Case 1.6 Qts. Front wheel gear case 0.5 Qts.
Walt this tractor it a little bitty one. My ford 841 looks like a monster parked next to it. Diesel 3 cylinder engine 16HP more or less a big riding lawn mower with a loader
