I have a Ford 800 with an early serial number (10129)that I am overhauling. I wanted to replace the clutch release bearing but it is mounted differently than I have previously seen. Instead of the the 2 springs on either side as with the 4 speed it is mounted to a bracket that doesn"t resemble anything in the Ford (5 speed section) or I&T shop manuals. There is not a fork or 2 springs like the other versions I have seen.
There is a large spring attached to the clutch release shaft on the left side (looking from the engine in) and it appears that the only way to get the bearing and it"s "hub" off is to take the release shaft out of the tractor. Can anyone help me with this? How can I get the release bearing and the bracket it is mounted to off without taking the whole darn thing apart?
Thanks in advance!
Lane
That sounds like the XX1 set-up, which is not tough to get apart. just pry one end of the spring free, pull pin that attaches fork to shaft get it started with BFH on shaft, pull shaft out.
