I have a 180,000 Btu Kerosene Forced air heater. It will run good and hot cold which can be 20 minuets or an hour and the cone turns real dark and it starts blowing smoke. I removed and cleaned the air intake filter but didn't run it long enough to get it to smoke. It has an air pressure guage on the air pump and is supposed to be at 4.5 psi on low and 6.5 psi on high. It's only at 4 psi on low and 4.5psi on high. I turned the adjustment screw all the way in and couldn't get the pressure to change. Could it be a wore out pump or dirty air output filter? Just a guess the heater probably has less than 400 hours on it.
