MSD
Hey Kevin, saw you were wondering what the JD guy's are using for a head heater over on FB. I picked up a Kat's 11409 block heater for $32 at a local auto parts place. It is a 400 watt one. Hope it is enough. Any one with a 3/4 NPT will turn into the head drain plug. See you in Waterloo!
Years ago our club had a "gun ": stuck a piece of reflective tape on either flywheel or damper pulley. Read out rpm on anything that revolved. A local plant used one to check rpm on electric motors. One of our members worked there. How we knew about it
I was good enough to give you my room at Sigourney. A simple thanks would have been appreciated. Had I known he needed it I would have given it to Jeff Gravert.
