Does anybody have a wiring harness or can you tell me how to wire up a 4 prong key switch like the one in the picture? Thanks
The terminals are marked,, do you not understand the abbreviations or not have a clue about hooking it up?
Batt- hot wire from battery
Acc- all accessories except ignition
Ign- to + post of coil
S or ST (can't see that one)- starter relay
Upvote 0
Center terminal is "Start".
Upvote 0
Ok sorry I'm guess my brain shut off for a minute. this is a positive ground system so I have the "b" labeled side going to the negative (hot) side of the battery and I have I going to the coil. Is the correct
In that case the wire from IGN should go to the - side of the coil and the + should be going to the points
Upvote 0
Here is how it is connected
Upvote 0
I doubt that you have the correct switch. I think that you want to be switching just two terminals, but there is nothing wrong with two terminals on the switched terminal.
Upvote 0
