Kingdoms Crops are in!
jon f mn
We got lucky and had a week of decent weather, just a shower Wednesday night, so I got most all my crops planted. Just a 5 acre piece that's always wet and a couple low spots I went around left. Things went pretty well for the most part with just a few breakdowns. The 1030 did well and runs good, sure pulls good too. I've driven a few tractors that performed above their ratings, and this seems to be one. It's just quick and snappy and when pulling really hangs in there. Funny how you can have 2 identical machines and one works good and the other not so much. Worked with 2 JD 4430s that we're that way, one pulled great, the other was a dog. Hope it stays this way
The 6 bottom plow really made it work, but the 14' disc wasn't much of a load at all. Kept track of the fuel and she burned about 5 1/2 gal/hr on the plow and a bit less than 4/hr on the disc.
The 830 is a different story, she's a pooch. I've driven a lot of 830s and it should walk along nice with that disc, but it really struggled. It shows 7500 hours on a working tach and it looks like the engine has never been apart. Doesn't burn much oil, but has a lot of blowby and doesn't start too good. This winter when I split it to fix the com I'll likely overhaul the motor too.
My grandson Gage drove it for a day, I'm not sure he was impressed. Lol. Said it was boring. Hope he comes back for more tho.
The corn planter worked great, just a few adjustments and minor issues to get started and it worked great. Had a chain get loose and come off, and forgot to bend a cotter pin in the drive that fell out and gave me a missing row for a bit, but looks like it will be a good unit.
The 400 I replaced the engine in seems to run good, starts like it should a d doesn't have much blowby. I wanted to hook it up to the disc and work it some, but didn't have time. But I think it will be good.
I didn't get any pics of the grain drill this year, too busy I guess. Lol. Anyway, here are what the fields look like now. This is south of the buildings and is corn.
This is west and south, and is about half corn half oats. It is mostly spring plowing and so is lumpy in spots where the yellow clay comes to the top.
This shows what it looked like after the first discing, where it was lumpy like that I hit it a few times to try and break them up, it was mildly effective. Lol. Glad for the nice slow rain today to melt them down.
This field is west and north of the house and is oats with alfalfa in it. It was fall plowed and really worked up nice.
I'm very pleased with the soil on this place, I was expecting a lot more of the mucky lumpy stuff, but over all that is a small percent. The rest is still very heavy and hard, but more mellow than I expected and works up very nice. The work I did on the ditches last fall and this spring really helped with draining the wet spots that were taking over. One reason I planted so much oats is so I'll have time when it's dry to work those down and get rid of the ruts and Finnish getting the ditches cleaned out after harvest.
So all is good in the kingdom today! I'm just sitting here drinking my coffee and listening to the rain and thunder and liking life. Wish more of you were in as good of a situation, but these rains look to keep coming for another week. I feel for those just waiting.
Nothing happening here. I am doing my part to draw down the surplus by not planting due to wetness along with others here.
You are luck very lucky. The wet weather is killing many farmers self included. The 400 looked good too.
This has been fun to follow, from the time you moved in, until now. Those buildings have to be greatly appreciated, keeping things inside and out of the weather. Soil is similar here, but probably more glacial till round rocks, with more percentage of gravel, soil here is typically well drained. That is a good feeling, getting everything planted ahead of the rains. Can't wait to see how it turns out this year.
Jon was that the case planter you were fixing this winter? You had a lot of repair to do to it.
It is! Took virtually every bolt and shaft out to free things up, replace bearings and such. Also had to re-gear it because it was only capable of planting up to 21,000 population. I'm very pleased with the way it's working now.
Jon F;
Thank You for sharing "Your Kingdom" with us. I look forward to following your progress. Now, we wait for the crops to emerge and grow. I hope you have a bumper crop! Dsmythe
Jon, great photos and you are very lucky to have had enough good weather to finish planting, please send some good weather eastward.
Re two tractors the same being completely different, we had the same with a couple of IHs, one was great good governor response and the other was always bogging down and the governor would not respond.
Dealer even changed the injection pump but no difference.
JimB
I have had a few every nut and bolt projects too. Can be cheaper than buying new if you have time.
That 1030 is pretty amazing to pull that much plow! I always got out and checked to see if all the planters were working at the end of each turn. I always thought if it was my crop, I would rig up a one row planter to pull behind a garden tractor or a ATV, to plant a missing row.
I had a 94 dodge diesel and my buddy had a 94 dodge diesel same rear ends same injectors same everything injection pump timing numbers on the pump could not find one bit of difference but mine would run away from his like you couldn?t believe never did figure out why
I'm not that far from you (west of Rice Lake,Wi). The farmers got some crops in at least on the lighter soils. Where I'm at is a more heavier soil type and there has been some seeding done, but had over an inch Friday night and today and more expected tomorrow so that will stop things for a while for sure.
DWF
