(quoted from post at 10:11:35 08/09/19)
(quoted from post at 20:31:59 08/08/19) Recently purchased a KingKutter flex hitch Dome Top 5 Ft Brush cutter. put about 10 to 12 hrs on it. Used on Light brush and Grass not abused or taken in areas that is out of its ability. The blades appear to be cutting through the top deck. Can not hear them hitting deck when running, appears to cut ok. Has anyone had this issue? KingKutter will not service or replace
Your description of it says "Dome Top 5 Ft Brush cutter".
Have you looked at pictures of this model? Because "Dome Top", to me, says that what you are seeing could just be the edges of the dome where it meets the rest of the deck.
Is there a weld joint there? If so, it might crack along that joint over the years. Alternatively, their bending process may have included heat along that particular line; which could make the metal brittle, if it wasn't cooled correctly.
Either way, what you are seeing may be a product of the original manufacturing process and how it changed the ability of the metal to withstand stress along that circle that you see.
If the blade was hitting, you would definitely hear it.
Check out some pictures of this same model, maybe the dome and that ridge is always there... yours happens to be cracking along it.
If it is, I'm not sure what the remedy would be, or even if it needs anything done to it.
If you welded straight along the seam, you could do more harm than good in the long haul.
