I recently bought a new Klein MM4400 multimeter to replace my Craftsman red/grey digital multimeter. I used the craftsman for checking 6 & 12 volt charging systems, lighting circuits, grounds, chasing wires, etc. The Craftsman worked great for that until it broke. I thought I would spend a little more and get a nicer one and went with a Klein MM4400 digital multimeter. I really like that it could measure temperature and had the backlit display as I work in the dark a lot.
QUESTION: I tried the simple task of checking the voltage on a 12 volt battery on my Farmall Super A tractor. The meter would not read the voltage on the battery (hooked up to tractor with engine off). All I got was 0.000 with the leads not hooked to anything ; then after hooking meter to battery I got fluctuation that looped constantly from 0.00 to 7.74 to 69.4 volts. When I started the tractor and ran it at almost full throttle I got the same readings that looped the numbers of 0.00 ; 7.74 ; 69.4 volts. WHAT AM I DOING WRONG!?!?
