Dune Country
to my fellow N'sters
Pulled oil pump due to low pressure, had bushing pressed in,installed new pick up tube, installed pump & pan didn't touch anything else, started it up and there is a knock, sounds like a rod but isn't (pulled plug wires one at a time)it is loudest around the drain plug, unfortunately I did not side by side compare old and new pick up tubes. Is it possible that the new tube was "clocked" wrong when installed on the pump plate? Are the tolerances to a crank throw that tight? the pick did align up with the drain hole, oh and the oil pressure is great
any ideas
any ideas
