Kohler command engine oil
Charles in Aus.
I have an old John Deere STX38 ride on mower with a Kohler 398cc engine .
Manufacturer's oil is twice the price as from the auto shop .
Can anyone please let me know what grade of oil suits this engine ?
Manual is useless , other information I have on the engine is that it is 13hp , model no. CV13S-21509 , with a 8.9 to 1 compression ratio .
Does it call for JD Plus 4 oil?
Found this, says it's API SL service, 10w-30 weight.
That is just automotive SL gas engine oil.
The API SL rating means: S is for spark ignition engines, L is the latest spec. The designation always goes up the order of the alphabet, so you can go with a higher letter rating, but not a lower.
If it was mine, it would get 15w-40 diesel oil, but your choice.
JD Plus 4
Thanks all :D
I was wrong John Deere oil is four times the price down here !
Now I am not limited to buying from the dealership I won't wince so hard when it's oil change time .
:D
Charles
We have several Kohler engines on augers etc. We use a good 10W/30 on them and on all small air cooled engines (mainly Honda; have over 20 of them on pumps,
compressors, generators etc. Have a few Japanese Honda clones plus some Chondas)
Always like your posts; especially on Fergusons
It's so good to be able to get real advice from men who know by doing Bob .
I use 10w30 in my Honda engines , mainly generators and hand mowers so keeping more of the same grade on hand is really convenient . John Deere Aust really do themselves no favours by marking up the price of consumables and parts so highly.
Some advice I can share on this Kohler engine , there are two oil filters available and listed for this engine , both fit and look identical BUT one will not allow oil flow when screwed down onto the mount . Examine any filter you get and make sure that the secondary outlet in the filter head corresponds with a hole in the filter . I will.try get photos next week to explain further .
