Kohler help needed
bweb
I have a Terramite with a 20 hp Kohler. I was using it to get gravel out of the creek and the engine started surging pretty bad. I have replaced the following. New plugs, air filter, fuel pump, fuel filter and a rubber hose that extends out of top of the engine and goes into the air filter base on the carb. I'm getting good fuel flow to the pump. Governor linkage is free. Still having the problem. What should I look at next? Thanks.
If this is a V twin I’d check intake gaskets. Just had a John Deere lawn tractor throw me for a loop and the gasket was blown out on one side.
Does pulling out the choke slightly stop the surging?
If so, you either have an air leak on the engine side or plugging of jets in the carb. No surging at idle says load jet is slightly plugged.
I'm with Roger. I have had the same problem. For 15$ I replaced the carb with one fro mEbay. Probably have varnish in the carb.
Have you considered doing some diagnostic work BEFORE you fire up the parts cannon?
Surging is usually caused by a mixture problem - and usually on the lean side. Check intake gaskets, carb base gasket, and any other seals in the air path into the engine. PCV systems on small engines are simple and commonly overlooked. Crankcase vent is another potential source of trouble.
Like Roger said,that is most likely a carb.When it comes to small engine carbs,you have to get the oem replacement or rebuild the original because any ordinary replacement will be chinese made throw away junk.
Rock
Good evening Bweb: I just happened to see the post, and comment about replacement carb. I have a Deere 212 L&G tractor, with 12 horse Kohler. I bought a carb from Amaz--- in spite of my own better judgement. I had to make up part of the throttle linkage, including using an old ball joint piece from a 9N. The Chinese carbs often do not have all the linkage you need (see You Tube). I got it started ok, and after a little adjusting, it has worked well all last fall and all mowing season this year. Cost was only about $20.00, seemed worth taking the risk. Just a comment from a bystander....
Dennis M. in W. Tenn.
Surging is usually caused by a blocked idle circuit in the carburetor. Disassemble the carb and clean out all the passages and jets with a fine wire or torch tip cleaner. I use monel fishing leader; MIG wire may also work. Soaking in carb cleaner doesn't usually work because it has a hard time penetrating the blocked passages.
Run some Mechanic-In-A-Bottle through the carb. Most amazing stuff I've ever seen! Tractor Supply, Menards, Wallyworld, etc.
(quoted from post at 11:22:11 10/26/20) I have a Terramite with a 20 hp Kohler. I was using it to get gravel out of the creek and the engine started surging pretty bad. I have replaced the following. New plugs, air filter, fuel pump, fuel filter and a rubber hose that extends out of top of the engine and goes into the air filter base on the carb. I'm getting good fuel flow to the pump. Governor linkage is free. Still having the problem. What should I look at next? Thanks.
Your 20 HP Kohler I am guessing is a Command series engine.
Depending on the age of it, the early ones had rocker arm issues, Kohler did a redesign and a kit was available to update the earlier engines.
Only takes a few minutes to remove the valve covers to see if a rocker arm is out of place (off the valve)
The one I did it ran perfectly at idle on 1 cylinder but very low on power when a load was applied to it.
The kit was surprisingly inexpensive and came with all the bits and pieces to upgrade it to the newer design.
Thanks everyone. I'm going to get some carb cleaner and check for air leaks. Will see if I can still get gaskets for the carb and go through it. I did replace the crankcase breather hose because it was cracked.
Ditto on the rocker arms getting out of spec (loose). Just takes a minute to pop the cover and check.....0.005 intake, 0.007 exhaust. If you tweak them
and find yourself tweaking again in a short period of time, remove the rocker and look down, in the center, where the retaining post rounded head nut
rides...will probably find it wallowed out.
