Kohler K301
I didint no if I should put this hear or in tractor lulling so I put it hear.
I have a few questions about my 12 hp kholer then engine got a Stock rebuild 1 year ago and Im looking to get more power with out building the engine.
1 will a carb spacer giver more power
2 can I get more rpms with out tearing apart the engine and leaving the govner installed
3 how can I get more go without rebuilding the motor
(quoted from post at 20:34:24 10/03/20) I didint no if I should put this hear or in tractor lulling so I put it hear.
don't think a carb spacer would change anything. More rpm's is probably a terrible idea, you could get lots more power if you put a turbocharger or supercharger on it.
First thing would be to get a tachometer and figure out if you are getting the full 3600 RPM's you should have.
Carb spacer requires a lot more RPM's to do much good and the standard cast flywheel won't take much more than 4000.
You can adjust the RPM's with the governor/throttle linkage.
You can get more power by doing what's called porting and relieving a flat head motor.
Kirkengines.com for that.
http://gardentractorpullingtips.com for more general information.
Be warned do not over rev a Kohler , the flywheel will explode. The casting is made of a low grade cast , ok 👌
3600 rpm ,that’s it ,period .
GardenTractorPullingTips.com is one forum that features tips on modifying the Kohler engine.
KirkEngines.com has some performance tips.
Keep in mind that everything that increases the performance also has the potential to decrease the durability of the engine.
