Komatsu D21A-5
Hello, I"m buying a Komatsu D21A-5 Serial # 54786 for $8,500.00. What year is it? It"s a power shift. What do I use for hydraulic fluid? Can I shift from forward to reverse without using the clutch? And what is a power shift model mean.
Thanks,
Frank
Hi Frank,
Go to the Heavy Equipment Forums site.
In the Dozer section,there is a special thread about Komatsu D21s,etc...& other owners to help you.
Jim
my s/n starts with 537 it said to be 1985 model,
I use 10 weight oil in transmission, engine 30
weight oil, hyd sys light weight non fomming oil
use on most tractor hyd and gear box sys
go to Search for {type in} Komatsu D21-5 in Crawers, Dozer & loaders it should take you to Komatsu D21-5
