Kubota B200 series
Craig2
I am going to look at a B200 series tractor tonight. It is 4x4 with loader. Owner says it is a first generation and the pto turns opposite of other tractors. It has a 4' bush hog and a woods finish mower. He says the mowers will work on it but you have to turn the blades over because of the opposite turning pto. Does anyone have any experience with these? Does this sound right? It is an older tractor, maybe 5200 or 6200 model. I will know more tonight when I go look at it.
I have a B5200. I bought it in 1987 new and I'm still using it. I've abused the H out of it and it just keeps going. Mine is 2wd though. I wished I had gotten the 4wd but at the time couldn't afford it. They still make parts for it however most of the time they have to be ordered.
You can't just turn the blades upside down. They are designed to create a lower air pressure above the blade therefore sucking the grass up. If you turn blades over they will reverse the pressure to push the grass down and would probably stir up a lot of dust.
