Kubota B8200 hyds problems
old
Changed all the fluid in this thing today. The transmission/hyds where a cream color. The hyds did not seem to work well before I changed the fluid and not much if any better now. 3 point might work as the same with the loader.
So #1 is there a filter in the hyd system some place???
#2 how many gal. of fluid does it take and will over filling it hurt any thing??
There is a suction strainer that must be cleaned periodically but rarely is. If it has been neglected too long, the pump is likely worn out.
You will likely need new O rings if you remove it.
Like any lubrication system, it should not be overfilled.
Hydrostats have a filter beneath the cover between the operators knees. Use a Kubota filter.
Dean
This one is a non-hydrostatic drive so that is not a problem. Suction pipe looks like it has a banjo bolt so I am guessing that is where the screen is???
