gavinhunter
Hey guys,
I bought a Kubota M4900 cab tractor this fall at a local auction, my intentions are to leave it hooked up to my produce sprayer all summer ( finally in AC )
The immediate issue I know it has is, it can be difficult to get out of forward on the shifter. I hooked it up to an 8 foot pull type disc to see if it would pop out of gear or anything under load and it didn't which is a good start. If you move the shifter forward ( lightly ) and let the clutch out its not truly engaged, you have to give it a firm push to make sure its actually in gear. Once its in, it does not pop out. That issue seems like it could be resolved with shift linkage adjustment. The part of it being difficult to pull out of forward gear somewhat randomly is my cause of concern.
What are some of your experiences with this type of problem? I've read a good bit on synchronizers, just want to see if i could be missing something before diving into that.
Thanks, gentlemen.
Thanks, gentlemen.
