roostertale1
I have an xg3037 that is giving me an occasional issue. Every once in and a when starting i will turn the key to glow plug position i get nothing. The glow plug light doesn't come on and the lift pump doesn't come on. After setting foe a couple of minutes the glow plug indicator comes on and the pump starts working and it starts up. I don't know if i have a lift pump going bad or if there is a safety switch in the starting system giving me issues. Any thoughts would be really appreciated.
Hello rooster, welcome to YT! Since your tractor is not
a main line machine I will help others out by giving the
info on it in the link. Have you tried to contact a dealer
about your problem? I am just going to guess that
there is an electronic board in it that operates some of
those functions. I am not saying the board is bad just
pointing out that it makes troubleshooting more
complex. I would suggest you acquire a repair manual
for the machine and go from there. At least it would
give you a wiring diagram to see what all may be
involved with your problem.
LS brand, XG3037
