L2 Gleaner Settings
I have an L2 that is setup for corn, I m swapping on the grain head tomorrow. I have the manuals that came with it but cannot find the info on setting the machine up for oats. Mainly the fan and thresher speeds. Could anyone help me out with these setting? Thank you in advance.
Jake
Starting point....cylinder speed 1000 rpm, clearance 1/4 inch, fan set at half
setting initially...That is the one you will be changing the most as the harvest
continues. Engine must run at 2400 rpm for proper threshing and cleaning action.
chaffer set at 3/8 inch and sieve at 1/4 inch and adjust as head and seed size and
sample dictates. Do a hundred feet or so, check the sample and ground under and
behind the combine and adjust as necessary. If the combine is in good condition,
they will do as good a job or better than any machine out there.
Good luck!
Ben
