L59 Mower for an A
Papa's41
Just getting started with my Model A, so I have a new guy question. With the right mounting hardware is it possible to use a Woods L59 mower that came off a Cub on the Model A?
Any information is appreciated.
direction of the blades is how you instal the belt doesent make any difference what tractor as they did have left hand throw for any tractor it would be installed on. NO the Cub mounts will not work on the A you need the mounts for an A if thats what tractor you are going to use it on. You will not like the price of the A mount as its quite large and heavy. Do not worry about blades direction its just how you wind the belt. You sure need to know what direction the blades are for wouldnt be the first time someone had the blades running the wrong direction or even had the wrong blades on the mower.
How do you wind the belts to change direction? As far as I understood The L in L59 stands for left hand thread or counter clockwise rotation. The 59 deck is right hand thread and clockwise rotation. The spindles and blades are different this is what keeps the bolts tight. I own one of each.
Yes, will work, but you will need the mounting hardware for the
A. Cub mounting parts won't work. Also, you will need the
pulley that mounts to the belt pulley shaft on the A. On the A,
the woods mower drives off the belt pulley shaft, not the PTO.
Belt on the cub is same as the A. Found this when helping a
friend with his cub recently and found the cub belt to be the
same as on my140 mower.
I'm also looking to buy a Woods L59 for my SA. I see a lot of mowers that are marked 59 instead of L59 that appear to have been used on SA's or A's because the rear mounting attachment is different than for the Cub. I also see a lot of people advertising L59 but the deck says 59, did Woods used to sell the L59 and the deck still said 59?
I understand if you have a L59 you want it to turn left because of the spindle reverse thread and CCW blades. If you have a 59 you want it to turn right for the same reasons.
But my main question is, if you have the right mounting bracket and drive pulley for the SA can you use either a L59 or 59 deck by just threading the belt for the proper rotation?
Another question, if you use a 59 deck on a SA, put CCW blades on it, and have it throw left like a L59 deck would, how likely is it to loosen and throw blades?
Gerry
If you have one of each the belt is wound different on the left throw from the right throw and you should know that cause if your belts are wound the same one of your mowers is running backward. Left hand blades do need to turn left same as right hand blades need to turn right and thats why the belt is wound different cause the pulley on the tractor turns the same way for both mowers.
