LA130 schematic
I have an L130, not sure same or not. Lighter Duty JD. When battery was going bad, funny things happened to the back-up button, needed to back up and keep running while mowing. It did nothing! I think it's got a small computer or board in it, that makes things work in order. That's why you can't just run a wire between the wires at a safety switch anymore. It keeps an eye on ALL the switches and needs info to make it run/work right. SO, low voltage also makes it not work right. Might try a new battery before "hacking" into the wiring. Check grounds too!
