Old Roy
Your last attempt on the Allis,
What you see in the bottom of that oil is water not gas, Gas will mix with oil and won't separate like that.
You didn't mention if the oil smelled like gas.
I would take something like a feeder plunger and put a hose on it and siphon the clear liquid off and reuse the oil til you get er running if the oil feels like it has a good viscosity. Then do a good change. Also you like fires, try to light the clear liquid to see that I may not be right about water.
I do like fire and it does burn.
Besides theres no water in it, she hold antifreeze now!!!!
It feels fine, theres just a layer of gas down there. We thought we had it fixed and the gas would seep down overnight instead of while we were pulling (hey im learning) and last night we pulled the plug. There was gas streaming out before we had the plug all the way off. It diddnt last though, and diddnt look like much more then there was in there the first time. And the oil wasny even black.
Is he getting spark, are the plugs wet or is he squirting gas in the cylinders, that thing should be popping, even turning over by hand.
shes a rebuilt mag, and nebraska kirk knows what hes doing so im not too worried about that. And theres a nice blue spark on all 4 cylenders
yes. We tried going around the house in thirds, first with full choke, then 1/2 choke then no choke
and i took the air cleaner off while im doing all this, so the carb is open and getting air
I didn't see the thread either if it was your last try. I saw it on Chucke2009 YT
You say you have nice blue spark !! Where ? at the plug wire or the electrode, {fuel chamber side ?]
If that was gas that just drained overnight You have big carb problems.
Shut the gas off completely and if you have a crank, " be dadburned careful" Give it a shot of ether, or squirt a little gas in the cylinders. and see if it will fire dry, use open left hand " Don't close your thumb around the crank" and when cranking pull it on the upswing, that way if it starts your hand should be clear if crank sticks. or it has a chance to pull away if Backfire.
Watch your legs also . Should at least chug a couple times. If so then redo the carb. Yor gittin er.
The spark I was referring to are the plugs too long and maybe hit piston and closed too tight possibly not correct spark at that point ?
idk, theyre the ones the local auto parts store came up with for an allis B. Champions. Book said gap them .030 to .040 so we did .035
I posted a message in the lower post you made . Hope someone sees it that is a good vid to go by seems like no one sees it.
lance check that new exhaust muffer make sure air will go though it, a gas motor need more than fuel,air,spark, to run it also need to be able to get rid of exhaust gases let me know what you find. good luck
Lanse, in your latest video, it's hard to tell but is your engine cranking ccw? It looks like it may be cranking cw for some reason. Probably just not seeing it right. Another thing, make sure the adjusting screws on the carb are set.
Yea but i diddnt.....
I will before the next time i pull her. It was short notice!!
they did get a nice bluish white spark on all 4 cylenders though!!
