Landing Mats
I know that someone out there has seen or bought "Landing Mats" like they used during the second war on the air fields. Does anybody know where there might be some of the "Mats" that might be for sale ???? I know it's a long shot,but the guys on YT are very good at this stuff Thanks Jim in N.M.
Correct term is Marston Matts. Might be helpful if you are searching the net for them. They do come up for auction on construction equipment websites.
Good luck finding some, you?ll be luckier finding a 50 lb gold nugget, no kidding, I?ve been searching almost 30 years for some. I know some folks in my area that got their hands on some 40+ years ago and stock piled several truck loads and will not part with it. Makes the perfect trailer decking if you can get some....
Well, not exactly. What I was looking at was some step/platform material from Graingers. Has two inch high edges. Marston mat appears quite flat, with interlocking edges.
Not sure if they?ll work for you, but during the last 2 gulf wars sand mats were used which are built along the same design as marston mats. Usually hung them on the sides of wheeled combat vehicles so when you got stuck in sand, just slide them under your tires and drive out, you could join them together as well.
Mobile home movers like them. Might check some of them. Mobile home movers seem to be scarcer than they used to be.
I don't know of any for sale but we had a bunch of them when I was young. I always called them panels because that is what we used them for, and what I still use them for, and gates too. I think the ones I still use are the only ones I have seen around for years.
There are tree trimers around here that use some sort of mats when they have to drive their bucket trucks onto lawns or off solid ground. You might check on some of the arborest websites.
Loren
As an underground miner we used many thousands of those landing mats to support ground in underground mines. Holes were drilled into the ground and long bolts with an expansion shell on the threaded end and a steel plate on the other end were put through one of the holes on the mat and pushed up against the ground. Then the bolt was tightened pulling the mat tight against the ground. Other holes were drilled through some of the other holes in the mat and more bolts added. The expansion shell worked on the same principle as the lead or plastic inserts used to hold a screw in concrete or drywall. Mats are still used in underground mines but they are made of thinner sheet metal but are still called mats.
years ago they were regularly for sale in the paper edition of 'Rock and Dirt' magazine.Its a big newspaper catalog.
Here?s some pics for those that don?t know what landing mats were....
