Nebraska Cowman
Lanse, The piston at the top means nothing. It comes up TWICE for every cycle. Once compressing the fuel mixture to fire (valves closed) and once to expel exhaust (exhaust valve open)
If you have the mag timed to fire on the exhaust stroke it ain't gonna run. Read my instruction again.
Chucky. There is nothing wrong with your tractor.
You need to time the mag right.
FIRST, (this is simple) Take out the #1 spark plug (thats the one at the front, closest to the radiator) Now with your thumb over the spark plug hole have a friend crank the engine over till you feel air pressure on your thumb, (you might have to try this several times to get it right. Once you start to feel some air coming out, STOP cranking. Now, with a piece of wire or something, (I use a screwdriver or my plier handle) poke in the hole and continue cranking the engine SLOWLY. You will be able to tell when the piston is at it's very top. Grab the fan and rock it back and forth a little to be sure it's at the top. (you might want to take all the spark plugs out so it turns easier) NOW....without moving ANYTHING, Take the distributor cap off. See which way the brass piece on the rotor is pointing. That is where the spark is coming from and it needs to get directed to number one cylinder at this time because it is the one that is ready to fire. (Do you understand how a 4 cycle engine works? ) Four strokes, Intake stroke, as the piston goes down, intake valve opens and fuel mixture is sucked in. Compression stroke, both valves closed, piston comes up and squeezes fuel vapor real tight, when at the top of the stroke spark occurs BOOM, Power stroke piston is forced downward by explosion, (I know you understand that) both valves are closed. Exhaust stroke exhaust valve opens as piston comes up and burnt gasses are expelled. The other 3 cylinders follow in like manner. In your case 1,2,4,3. Let's see, now, where was I? Oh yeah, The rotor. Look at that pointer piece. Now look at the cap. Is it pointing toward one of the holes in the cap? close to it? before or slightly after? Slightly after is good. Before will break your arm. Stick #1 plug wire in that hole. (nothing else matters at this point, let's get the tractor running first) Now continue in a clockwise direction and insert the other plug wires, 1,2,4,3 and reinstall the spark plugs. Try starting it now. Unless you have had the magneto apart and messed up the internal timing (very easy to do) it should at least try to run.
sounds about like what we did
Cowman,
This procedure is what we all have been preaching to Lanse, he seems to only pick up on what he deems is the "most" important part and tends ignore the preliminary and follow up steps. You notice his answer was "sounds ABOUT like what we did". I've been working on these old jewels for 50+years, first out of necessity, now for "FUN" and get really frustrated when someone like you gives very detailed instructions and they are only half @SSed followed. What's the status of the F20 rebuild project?
I wonder if one of the More knowledgable guys on theis forum were at Lanses house how long would it take to get that tractor running. Not putting Lanse down at all. Everyone has to learn but I'll b et its something simple. Bernie Steffen
