late 720 diesel thrust washer
greendiesel
hello, i know that the original crank thrust washers (one on outside of main houseing and one on the inside) are the fiber type. i just took off the flywheel and the crank seal houseing on a late 720 diesel (#7216162) i did not yet remove the spacer as it is being a buger to get off but i see that i copper looking thrust waser is behind the spacer. it looks like it has tabs evenly spaced around the outside that touch the outside diamiter of the timeing gear houseing and the surface that rides against the spacer has evenly spaced groves in it. i hear talk of a erly type(the 2 washer on outside with metal spacer in center and no washer on inside of main houseing) late type (one washer on outside and one on inside of main houseing) and a update type -is this the update type? has anyone seen this befor? thanks
