leak water pump on a B
That price is fair for the one with the bypass hole.
If you don't need the bypass you should be albe to find one for $100.00.
Try Tony"s Tractor
If there is a plug in the side of the pump you have the one with the bypass that is not needed.
Go to Tony"s Tractors site {Google It} and look at the pumps under radiators and cooling.
i think either pump should be o.k. for the B or C. I believe the smaller D series used the same size pump and the bypass was needed on them.
