Leaking HEAD GASKET JD 60
Would like to find out if there was a SERVICE BULLETIN issued enregardes to these head gaskets leaking at that time if so what # I have been told and also read on here 60,s were an issue and what was recommended correction at that time Also TODAY. Thanks for an info.
Yes, this issue was addressed but I don't have the number of the Service Bulletin in front of me. I've modified the procedure somewhat and it has never failed to work. Put No. 3 Permatex on both sides of the outside rail of the gasket. Install the gasket and tighten in 10 ft./lb. increments evenly to 150 ft./lbs. The small increments are key to a nice, even torque setting. Retorque after a heat cycle and the gasket should never leak. The only time I have ever had a failure was when a customer wanted to use Kopper Kote instead of Permatex. I have two cans of KK I would gladly give someone. Mike
