I have now taken off the hydraulic pump 2 times to try and fix it from leaking. The first time I thought I had it ready to go after replacing the seals and bearings but it still leaked because I rolled over the lip of the seal. I replaced that seal but it still leaks badly, I was thinking the shaft may be worn causing it to leak. There is a worn area, but it is only about .003" smaller, would that cause a pretty significant leak? What would be the best way to build it up? I have stick and mig welders in my shop, but I could have it tigged at work. I am a machinist by trade, so that part shouldn't be a issue.
Thanks,
John
Thanks,
John
