Forward slash
I bought this old 49 8N some twenty years ago. It's needle and seat were leaking, so I replaced it. It leaked. I've lived with it all this time because I seldom use it anyway. It's truly just for occasional uses, but when I need it, I need it. I would just turn the fuel off and let it starve out. I've decided to go through the old thing since I have more time on my hands and I am after all a factory trained GM tech with ASE master tech certification, and I grew up rebuilding carbs. Went through every iteration of computer controlled carbs and am so glad they have for the most part gone away. Now I've gone through the steering gear box, replaced my brakes and axle seals, painted all the sheet metal, treated it to new light switches, ignition switch, and other refab work. Nice new radiator. And I got another needle and seat for it, but it just leaks like it has always done. Before I went for this latest set, I had used my battery operated drill motor and a 7/32 hex to spin the needle in the seat to get a better seal, and for a few days it worked. I could go out to the shop and cold start it and it would start right up and prove out not to have leaked overnight. That lasted for awhile. So I thought I'd try the third set. No go. I see nothing wrong with the float. It's not hanging up inside the chamber. Does anyone else have this experience and does anyone know of a float that is built with more buoyancy. I took that little spring out that pushes down on the float. I've read posts talking about needles sticking, but I have the opposite problem. I hate to throw parts at problems, but I would sure go for a new float if it would do the trick. Would sure welcome any help out there. Thanks
