Leaking poppet style SCV
MJMJ
One of the SCVs on my 2550 has developed an internal leak. For example, with the baler hooked up the gate will slowly raise. I've just used the other set this summer but would like to have it fixed. The local hydraulic shop won't touch it, said they can't fix it. So far haven't had any luck getting the local Deere service shop to pick up the phone.
Am I right to assume this can be rebuilt? Or should I just try to find one at a yard?
I can re-build them here and bench test them,,I do them a lot,,my mail box is open..
That would be great. I am not able to send you a private message. I suppose I need more posts. I will try to get enough and PM you soon. Thank you.
Okay, looks like I am having trouble figuring this out. I cant seem to find a way to message or email?
Thought I d bring this back up top. Tim fixed me up last year and everything worked great. But mowing hay a couple weeks ago, apparently it has started leaking again. Not near as bad, but noticable with the haybine. Is there something I should look for that could be causing it, or just bad luck? Thanks.
