Leaking PTO on 7060
Two shaft seals and a very thin O-ring. Pull drawbar out. Drain 17 gallons of rear end oil. Remove the cover plate above the drawbar. Large castellated nut with a lock pin gets removed. A slide hammer connected to the center shaft will pound off the front bearing. A 9/16" wrench will remove the 5 or 6 retaining bolts for the hollow shaft. Use light RTV on the new O-ring when reassembling. Takes about 3 hrs to do. Best bet is to drain oil and remove the cover plate the night before to let it drip dry.
