TO30
I posted this question in the wrong area and I was ask to post it here.
I installed a new water temp gauge and the temp sender is dripping. I know there is an issue with some temp sensors being too long , causing the mounting nut not to tighten down, this is not the case. The temp sensor is not bottoming out on the back side.
I have tightened down on the nut as much as I can, but it still leaks.
Can I use a sealer or silicon around the sender to help seal it?
Rick
Rick
