Casey in Ky
Both lights are out on my 92’ Ford 4830. Considering changing just the bulb over to LED’s. Any issues with doing so? How do the LED bulbs work with the older electrical systems? Any improvement over the plain halogen bulbs? Thanks
New enough so you're 12 volt, negative ground, no flasher involved, should be fine.Both lights are out on my 92’ Ford 4830. Considering changing just the bulb over to LED’s. Any issues with doing so? How do the LED bulbs work with the older electrical systems? Any improvement over the plain halogen bulbs? Thanks
If you are using the tractor on a livestock farm, especially cattle, I would strongly recommend not to go LED. These LED light have spooked livestock enough to stamped taking down gates, fences and injuries. Otherwise, if you are just doing crop work, no issues.Both lights are out on my 92’ Ford 4830. Considering changing just the bulb over to LED’s. Any issues with doing so? How do the LED bulbs work with the older electrical systems? Any improvement over the plain halogen bulbs? Thanks
Makes a difference if they are a spot or a flood LED some bars have both.If you are using the tractor on a livestock farm, especially cattle, I would strongly recommend not to go LED. These LED light have spooked livestock enough to stamped taking down gates, fences and injuries. Otherwise, if you are just doing crop work, no issues.
LEDs are narrow band, cast odd shadows enough to spook animals to no end. Incandescent bulbs are way too dim. Halogens come in a wide range of wattages and brightness.
If you snow plow or snow removal, some of these LED light-bars wash out the snow so bad, you can't make out what was plowed vs drifted in the LED cool bright white spectrum. And forget using them in the fog. LEDs are the worse.
Pick what works best for your application is all I could recommend.
I there is a flasher, you just have to get a flasher that works with LED bulbs. They not rely on currrent through the bulb to flashNew enough so you're 12 volt, negative ground, no flasher involved, should be fine.
I agree that the leds on some vehicles are blinding, but this is about his tractor lightsWhy blind oncoming drivers?
