New to me 8N, 1952 by serial number, 12V conversion. I installed some LED lights on the front. Connected fused hot wire to the terminal junction that was hot with key on to a switch and back out to lights. Grounds ran back to the dash structure. With engine off key on I tested lights and they worked. Started engine and they came on for a few seconds, started flickering and died. They are fried now and I'm not sure what happened. I used the same wiring and tested with an incandescent light and it works fine. Is there some kind of electrical noise in these older tractors that could have caused this? Voltmeter shows 12.5 at battery with engine off, 14.1 while running at 800RPM. I'm going to have the alternator tested to verify its good. Anyone else have this issue? Thanks.
