LED replacement bulbs - Again
Boss Hog
Location
Central Illinois
I posted a thread a few minutes back. But when I click on it there's no text or reply button. I'm not sure how that happened.
Here's what I was asking:
I saw a thread where someone had changed out the headlights on their tractor. I'd like to have LED headlights on my MF 35, but would like to keep the stock housings.
According to the AGCO parts book, the correct part# for the headlight bulb is 1754916M91.
I tried searching for an LED replacement for that part number. A couple of links came up:
https://www.external_link/ABC3474-12-Volt-LED-Lamp-trapezoid-beam-pattern
and
https://www.external_link/ABC3490-12-Volt-LED-Lamp-Flood-beam-pattern
But neither of them list the AGCO part# in their reference list.
Anyone have an idea if those will fit the stock MF35 headlight housing? Or know of another LED replacement bulb that will?
If this is the correct link, looks like the needed info is:
"4-1/2" diameter bulb"
"Direct replacement for 4411 sealed beam or H7610 halogen"
If that matches up, I would say they will work. The important numbers are the diameter. The lamp numbers could cover several different specs, not so important, but something to go on.
In my OP I had links to an external website. Maybe that's why the posts got "censored".
Looking at this link:
https://www.yesterdaystractors.com/Massey-Ferguson-35_Sealed-Beam-Bulb-12V_70230252.html
The replacement bulbs should be 5 3/4" diameter. The LED replacement bulbs I found are 4 1/2" diameter.
So I guess the answer is that they're not available. Unless there's a sourse I just haven't found yet.
