Ultradog MN
- Location
- Twin Cities
Two years ago I built a rotary phase converter.
I had gotten a 7.5 hp 3 ph motor for free and bought a kit with all the capacitors, etc and found a 12x14in enclosure box on CL to put it all in.
At the time, I had second thoughts about the motor because it spins 3450 rpms and I thought a 17xx motor would use less power - because it spins slower.
But you guys assured me it wouldn't make a whole lot of difference.
I had my electric guru friend Steve wire it up for me and he is kind of a gizmo freak.
He handed me these gizmos and said to cut the openings in the enclosure cover which I did and he wired them in.
Fast forward 2 years and last week I bought a 7.5 hp 3 ph 1725 rpm motor at the U of Minn surplus outlet for $20. It had a noisy bearing so I replaced both of them ~$50.
Then I installed it in place of the old 3450 motor.
Thinking I'd make a smug post, I took a photo of the readout gizmos before and after I switched motors.
But no smugness now. You guys were right - of course, there's not much difference in energy used.
This photo shows the old motor using 543.3 watts at idle.
And here is the new motor using 507.4 watts at idle.
35.9 watts difference. So you guys were right, motor speed is Not a big deal.
One big difference between them is the amount of noise they make.
The old one was Really Loud. So loud I put it outside with a 5 gal. pail over it to keep the rain off.
The new one is Much quieter and I put it inside.
Meanwhile, thanks for all the great help we get here.
