let the smoke out again
cjunrau
I was reading on tool talk about welding table and the showed pics and talked about old welders.
Now I have burnt up so many welders and they look and some are exactly the same as the ones often posted on this site.
Am I welding so much more than most on here or is there something I am missing when I weld that causes them to burn up.
I have burnt up 2 brand new Lincoln 250 welders. and at least 4 older ones.
I weld with 6011 rods. usually set at 90-125. I weld lots of oil well pipe and 1 inch tubing.
Hmm. I bought a new Lincoln ac Tombstone in 1984. I built trailers, beds for trucks, welded on tractors. I'm sure I exceeded the duty cycle many times. Always used at least 1/8" rods. 6011, 6013, 7018. It was still melting rods when I sold it three years ago and bought a used ac/dc stick transformer 230 amp welder. I abuse it too. Never a problem. I don't think I even know anyone that has burnt up a transformer welder. Are you talking about inverter welders?
Only time I burnt up a welder was working in a factory making electrical boxes. It was spectacular, blew out the welder the circuit breaker and the main fuse for that half of the plant. Told maint before it was bad, when I would strike an arc the grind dust would gather around the leads from about four feet away
What is the incoming voltage? If it is too low it may cause more heat. A motor will burn out if the volts are too low. Are you sticking it a lot? 6011 are good at that.
It's called duty cycle. It is stamped into your welder some where. My 1970's Lincoln Tombstone 180 AC only is rated at 20% duty cycle at 180 amps.
Weld for a few minutes then let it cool down.
Beagle
(quoted from post at 10:35:45 01/21/21) I was reading on tool talk about welding table and the showed pics and talked about old welders.
Which model Lincoln 250? You are using 6011 rods, are you using AC or DC? Welding machines have a duty cycle rating, so many amps output for so many minutes out of 10, which allows some cooling time. Constantly exceeding the duty cycle will shorten the life. If you are welding steady for long durations you may need a heavier/higher duty cycle machine. Is your power supply correct? Small or long extension cords, if used, can reduce input voltage. As for used machines, those are a gamble to begin with in my opinion. You don't know how the previous owner(s) treated them. I will say I think a lot of the old machines are built heavier than new ones. I have an old Westinghouse AC machine I have welded with for years using about every type rod from 6010 to 90 series and used Chamfertrode as well and it keeps going. JMHO
Well i have welded a lot to ,on my buzzbox, and when it gets to hot, or goes over the duty cycle, it shut itself down, but the twentieth century welders were 30% duty cycle,more winding in the secondary coil! But i think you got low voltage !!
I have burned more than my share of wire (6011, 7014, 7018) 1/8" and larger over the years with a Lincoln 180 tombstone buzz box that I bought used in 1968. I've replaced the leads twice and cooling fan three times over the years. Most times I weld steady until the stinger gets too hot to hold onto. Although aware of the duty cycle I never did pay much attention to it, but it still strikes an arc.
I don't know.
In 1968, my wife gave me, as a gift, a 230 amp stick welder she bought from Montgomery Ward for $108.00.
Over the 53 years since, I've built several trailers, numerous stock cars, and done all of the usual repair welding, plus many other fabrication projects.
It's never "burnt up". Was I lucky?
I bought a Lincoln 225 amp AC welder in 1983. This was a new welder with copper wound coils. A few years later Lincoln changed
the coils to aluminum wiring. The aluminum was much lighter and would not handle the abuse of the copper coils. Easy to tell
which coil material was used. The copper welders are much heavier when you lift them.
Gene
Two things come to mind. First you have a voltage problem. Call an electrician to test it. Second is you are overworking. You are continously burning rod till the machine melts down. They have a limited 'duty cycle'.I have an 'old' lincoln 'tombstone'. No telling how many thousand of pounds I run through it in the last 35 years.
Are you exceeding the duty cycle? I have a small ac dc Miller that I bought new 30 years ago. Have gone thru at least 2000 pounds of rod and have not had a minutes trouble. Weld a stick or two and then let it cool for a couple of minutes.
Is this at work or at home? If it's at work, it may be wired to a 208v panel.
Still it would take a lot of high amp welding to burn it up, but using a home duty welder in an industrial setting is not going to work.
Did you look inside to see what burned up, was it actually the transformer, or was it a connection?
I must just weld to long. I weld for 4 hours non stop. I have melted the rubber off of the ground wire more than once.
Voltage coming in is not the issue. That has been checked again and again.
I will admit the cooling fans have quit I didn’t notice it.
Some of the used ones never had cooling fans.
Maybe I should rig up a big fan on it to cool better.
I did buy a mig welder for building square tubing panels and it got real tired to stand around waiting for the thing to kick in again.
I guess I’m going to have to buy a 100 percent duty cycle
When we build panels all the pieces are cut and we throw them in a jig and away I weld.
Do one side sflip do the other and start the next
Maybe 2 minutes to fill jig and 1 to flip.
My thoughts are: first, input voltage is low; second, shop wired incorrectly; third, duty cycle exceeded; forth, something you have forgot to mention to us.
(quoted from post at 09:24:57 01/21/21) I must just weld to long. I weld for 4 hours non stop. I have melted the rubber off of the ground wire more than once.
I will admit the cooling fans have quit I didn t notice it.
I guess I m going to have to buy a 100 percent duty cycle
I was going to respond that you couldn't be exceeding the duty cycle unless you were doing production work with everything already cut and with jigs to put it in. Now it is apparent how it is happening.
If the input voltage is low the output amps will also be low but not burn up the maybe his cooling fans fail and he mite be exceeding duty cycle
(quoted from post at 13:24:57 01/21/21) I must just weld to long. I weld for 4 hours non stop. I have melted the rubber off of the ground wire more than once.
Were it me, I'd look at the welder I had and see if I couldn't do more cooling on it. I've seen 100% duty cycle type welders at a local plant and you're talking a water cooled machine costing tens of thousands of $$$$. Maybe take what you've got, pull the cabinet off it, clean it out real good, lube the fan and see if there's a way to safely increase cooling. Maybe additional venting and some forced air from something like a carpet drier or the exhaust from a shop vac. If you're melting ground cables, you need bigger cables!
Dad has an old Lincoln 225 AC. We have re faced cat tracks and melted the rubber off the cables. Had the rod holder so hot I wrapped a rag around it and kept going never had a problem with the welder itself. Just the cheap ends he buys for the cables. They also have been extended so more line drop on them.
(quoted from post at 12:24:57 01/21/21) I must just weld to long. I weld for 4 hours non stop. I have melted the rubber off of the ground wire more than once
Wait, What??
4 hours!!
Melting Insulation off of leads!!
Holy Cow!!
Take a break man!
You will smoke a new one in minutes welding without a fan! They get hot even while idle from the core losses. I have seen some old monster ones that are naturally cooled but they aren't common.
1: if you are melting the insulation off your cables, they are not big enough.
2: assuming you are talking about an Idealarc 250, the duty cycle should hit 100% somewhere around 90 amps. Lincoln doesn’t publish very good duty cycle rating.
Also keep in mind the amperage on the pointer is just a guess. You arc length makes a huge difference in the amount of amps you are pulling.
The only welder I have is an engine drive. One of the thing I love about it is 300 amps at 100% duty cycle. You will overheat before the welder does. 50 ft of 2/0 cable. Never have an issue with the cables getting hot.
(quoted from post at 23:01:22 01/21/21) 1: if you are melting the insulation off your cables, they are not big enough.
2: assuming you are talking about an Idealarc 250, the duty cycle should hit 100% somewhere around 90 amps. Lincoln doesn t publish very good duty cycle rating.
I'm hoping to get an Idealarc from our local vo-ech schools auction later this year. What a step up from a 180 buzz box that will be!
My old AC Lincoln 225 from the early seventies used to start stinking when I used it too hard but it held in there. The selector dial finally gave up the ghost after 30 years so I put it in the back of the barn. It would have cost more than the welder was worth to replace the dial and I was getting a hankering for an AC-DC welder anyway at that time. Once in awhile I still think about replacing the dial to make it usable again just because it is a tough old welder that will not die.
