New to Blue
- Location
- West Central MIssouri
New to me 1973 3000 diesel with PS.
I have rebuild the steering sector gear box and the power steering valve.
Steers real nice to the right but kind heavy to the left even with front end off the ground.
I got to looking at the left side steering components and have noted a few things that need attention and I'm looking for input on these:
Left spindle needs new bushings 1/8 - 3/16 +/- of movement.
However while looking in that area I noticed the bolt attaching the radius arm to the front axle is broken off at the bottom.
Radius arm is also loose where it attaches under the sector arm to the socket and cap.
Finally the front axle is loose on the pin, probably 1/8 - 3/16 +/- of movement of the axle on the pin.
As you probably guessed this unit has a TA-25 loader on it, lol.
My questions are:
Does this axle pin require replacement? I&T manual states a "free fit".
Is the ball on the end of the radius arm replaceable, seems only the arm itself is sold, or is it just a matter of replacing the socket and cap?
Why would the bolt attaching the radius arm to the axle break, wrong grade?
Finally, and I know hard to tell with out having torn it apart. Are the spindle and outer axle easily damaged if the PO neglected the spindle bushings?
Any other input into this area is welcome. first time tractor owner... so yeah
Thanks!
My questions are:
Thanks!
