Drew.Styduhar
1978 Massey 20C (diesel)
Hey guys,
This is going to get sort of technical so bear with me
Carrier Preload
I went to install the left trumpet housing (right side was never removed) but could not remember if there was previously a gasket or just RTV....or both! The ring and pinion had been replaced some time ago by a tractor shop and I had to put the project on hold for a month to focus on something else so it's not fresh in my mind and all the mess was vacuumed up long ago. I could visibly see some places where rtv was used and bulged out but it was only in select spots near the bolts so maybe just to seal through holes in the casting?
I understand the gasket (.007" thick) is critical in setting the carrier bearing preload (spec is .010-.015) and after debating things for a while, I just decided to try and check things myself. As we all know, just because something was repaired at a shop doesn't mean it was done RIGHT. I guess its possible to set up carrier preload without the gasket, right? Its also possible they just put on a new R&P and put it all back together without checking ANYTHING.
As a rough check, I set up a dial indicator at the top (top cover is off) to measure the carrier side movement best I could. Yes, the pinion is still installed. You can't get a straight shot on the ring gear with the dial indicator so the pointer is at an angle, unfortunately. I put three .020" feeler gauges evenly spaced between the trumpet and axle housing and tightening down the corresponding bolts.
Again, I know I'm roughing it here but here's what I'm thinking:
I'm not sure what the community feeling is on trumpet gaskets vs RTV only?
As much as I just want to move forward and slam this back together with RTV only my gut feeling is I need to shim the right-side cup to compensate for the left side gasket thickness and add the gasket back in for proper install. Thoughts?
Thanks,
Drew
Carrier Preload
.020 feeler as shims = ~.007 repeatable side to side carrier movement. Prob closer to .010 since indicator is at an angle.
.007 feeler as shims (simulate gasket) = no side-to-side carrier movement
no shim at all = no side-to-side carrier movement
.020 feeler and no gasket (RTV only) would prob put the preload around .010 or so (.020 shim -.010 freeplay). This assumes compressed rtv thickness is basically nothing.
.020 feeler AND gasket would put the preload around .003 (.020 shim - .010 -.007 gasket). Not enough preload.
Thanks,
Drew
