levers on an M
partsman64
I recently aquired a 1952 M farmall and just had a couple questions. There is a lever an the left side that when forward the hydralics work and you have to pull it back so the transmission engages. On the right there is the normal lever that goes to the belly pump but there is also another lever that goes to the very bottom of the belly pump. Any help would be appreciated.
You have a Farmall with accessories! I think two sepearte add on parts.
The first is a M&W hand clutch. It actually operates a disk clutch in the left brake housing. Disconnecting the bull pinion gear from the bull pinion shaft on that side.
This puts the final drive system out of action when in the released position. The advantage is that the PTO can remain in action (bailing, mowing, or other work requiring intermittant stopping with PTO going.
The second item is a 9 speed transmission adapter allowing 4 more speeds between normal 4th and the normal 5th (road gear). Heisler, and M&W both made these components.
These options are desirable and add to the value of the tractor. JimN
