leyland 270 3pt don't work
super bee
I"ve been digging all over inside my leylands lift assembly . the lift dont lift. the fork engagement was severly worn and bent. i"ve replaced it with a new one. i have had the back apart 3 times. all valve seem to be working properly but the cylinder that pushes up the 3 pt won"t push. with the right lift/lower shifter in lower it gurggles / bypasses oil past this valve. is this normal?
sounds strange to me... i take it there is oil being pumped else where, the remote vales for instance, otherwise if there isn"t i"d check the intake filter for the hydraulic pump. I"ve found the following forum good for Leyland questions... (you will have to create a login to post)
Leyland Forum
